No serial port at max
Refering to the attached images, i have a VI using serial port which i have already programmed in 1 PC. After i've installed LV and DaqMX on the 2nd PC and try to run this VI, it doesn't work. Then i realised the 2nd PC does not have Serial port detected at MAX->Devices.
What could be the problem?
I'm using LV 8.2 eval and DaqMX 8.5
(2,929 Views)
Atma,
you missed to install NI VISA on the second PC.
hope this helps,
Norbert B.
Norbert
Expert: Geometry
(2,924 Views)
But i didn't install VISA on my first PC
(2,921 Views)
Take a look into the software-folder in MAX. If you installed a default installation from one of NIs ADEs (e.g. LabVIEW), the driver-CD is installed after the ADE. The driver-CD contains NI VISA....
hope this helps,
Norbert
Norbert
Expert: Geometry
(2,919 Views)
I'll try it again...thanks.
(2,916 Views)
Make sure the folder C:\Documents and Settings\All Users\Application Data\National Instruments\NIvisa exists and contains the file visaconf.ini.  I had a computer where the folder was never created, and then VISA failed to detect any serial ports.  As soon as I created the folder and restarted MAX, visaconf.ini was automatically created and the serial ports were there.
(2,899 Views)
