No scrollbar on probe with array of larger data type
So, I would file this under bugs, but I thought I throw this out there.  I am trying to probe a wire in LabVIEW 2016 that carries an array of a data type that large (i.e. extends beyond the viewable area; see image below).  If I view a single element of the array on a probe, I get the vertical scroll bar.  Has anyone else noticed this?  Is this intended behavior?
(3,959 Views)
What I see is an empty array.
Does it show the same when filled with data?
greetings from the Netherlands
(3,906 Views)
Yup.  And I would still say that even with an empty array, the lack of vertical scrollbars preventing a view of the full cluster is a bug.
(3,900 Views)
Hi Cirrusio,
This isn't something I have personally worked with. However if you think this is a feature/bug that would help people, please post on the following forums with a suggestion. R&D monitors these forums for ideas such as this.
 http://forums.ni.com/t5/LabVIEW-Idea-Exchange/idb-p/labviewideas
Andrew M
(3,873 Views)
I don't understand.  I thought the idea exchange was for new ideas that are voted on by the community, not bug reports.  This just seems broken.   But, I guess contacting R&D directly might be the correct answer.
(3,868 Views)
Hi Cirrusio,
If you do believe that you found a bug in LabVIEW the best way to report it would be by making a service request. To do this you would go to ni.com/support, scroll down to service request manager and then open a request. Thanks for helping us make LabVIEW better!
Maura W.
http://ni.com/support
(3,843 Views)
I just tried this on LabVIEW 2017 and it has the same behavior. It seems like a bug to me.
(3,834 Views)
