No plot on XY Graph
Hi Forum Members,
With reference to the attached LabVIEW 2010 vi I am having problems getting the XY Graph to plot my data.  Currently the XY Graph doesn't show anything when the program is run.  I have set the X-axis to read the simulation time and the Y-axis to read the scalar value from my data via the .csv spreadsheet file.  I know that the data from spreadsheet file is being read correctly since it displays the full set of data in LabVIEW.
I have checked through the parameters for the XY Chart and set it to a red line with thickness but I cannot understand why the chart is not being plotted.
Any help would be most grateful.
Message 1 of 8
(7,055 Views)
Accepted by topic author bunnykins
Apologies folks.....I just found that there is a "Clear data on each call" check box that needs to be cleared in the 'Build XY Chart' function.
Message 2 of 8
(7,052 Views)
I am having the same issue with my graphs. Where is this option??
Message 3 of 8
(6,789 Views)
My graphs were showing a while ago but not they show nothing. what is wrong?
Message 4 of 8
(6,788 Views)
Double click on the Express VI's.
Message 5 of 8
(6,782 Views)
my problem is not that. the thing is that it was working few months ago now I cant plot any graph in any vi
Message 6 of 8
(6,771 Views)
i think there is something wrong with the setting of my computer or osciloscope.
Message 7 of 8
(6,769 Views)
Well, your message right above asked about where the clear option was located.
Since you have started a new thread with your question, just continue there.  If it worked before, and not now, then SOMETHING must have changed.
no plot on xy graph
Message 8 of 8
(6,767 Views)
