No output from Simulink to LabVIEW with Simulation Interface Toolkit (0/1)
I'm able to send data from labview to simulink, but the labview
display doesn't show any output from the simulink model. I've attached
two very simple labview and simulink files which gives me this
problem. I have the same problem when trying to implement the sinewave
example in the manual for the toolkit as well.
I'm using LabVIEW 7.1 Pro, Matlab 6.5 and Simulink 5.0 on WinXP pro.
(2,598 Views)
The Simulation Interface Toolkit 2.0.1 or earlier does not work with LabVIEW 7.1. There is a patch available (or available soon) from NI support that corrects this problem. THe patch is Simulation Interface Toolkit 2.0.2.
(2,598 Views)
