No list tree of device and interface, software in MAX sytem. using pci 6034E and chasis 2345
Hye, i got the problem about this device.
I using PCI 6034 E which will connect to SCC 2345 to measure current and voltage.
My os is 32 bit Windows XP.
First i install this software, my MAX listed the tree of devices & interface which is PCI 6034 E and chasis 2345, and all download software are listed in tree of software.
By the way, when i start to measure the current, my MAX is working fine.. but, the problem is starting in the next day, wheni try to measure againt, all the list are dissapear. Then i uninstall all the NI component and reinstall again. Thereare a lot of install and reinstall again and again.. By the way the result is still same. Do not have any tree appear..
so, any colution for my problem?
i try to solve this problem, and i read that when the tree of devices and interfaces not appear, it's maybe because we using driver : NI 488.2 , i try to uninstall this driver.. by the way the result is still same...
(4,880 Views)
sahizansalman,
It looks like the same is happening with the Software list. This is often a sign of a MAX database corruption. I'd try the steps outlined in this knowledgebase:
What is the Process For Removing MAX Database Corruption?
Feel free to post back if this does not work.
By the way, do you know what device is showing up as unknown in the device manager? You did not mention anything besides your PCI DAQ card and SCC 2345, which are showing up fine.
Message Edited by mishkin on 03-11-2010 07:42 AM
Misha
(4,833 Views)
i try to follow the instruction process for removing MAX corruption base from your link,
am i need to uninstall and install again the software and hardware?
(4,812 Views)
No, there's no need to uninstall/reintall anything. It's a matter of removing certain corrupted folders and re-opening MAX so that it'll regenerate those files.
Misha
(4,807 Views)
hye... i already format my pc..
and now, my MA is working normally...
my MAX already detct my software and hardware...
thank you... Smiley Happy
can i ask about LAbView programming here?
or i should create another thread?
(4,770 Views)
