No driver and no source code
Hi there. I am currently carrying out a project using a Fab@Home D printer and have not been able to obtain the source codes. The developers are searching for these for me but have still not gotten back in touch. The D printer is connected via a USB port and I have been trying serial drivers to try and control the stepper motors that it uses. However the computer will only recognize the connection and cannot send commands through it. I was wondering if there was any way to by pass having either a driver or source codes? I have tried controllong the components separately but due to my programming skills have been failing. Any advice would be appreciated. Thank you.
Luke McLellan
(2,858 Views)
You need to command set.  Without that, you can't really do anything.
(2,849 Views)
It looks like this wiki has software:
http://www.fabathome.org/wiki/index.php/Fab%40Home:Software
Is it VCP serial commands? If so, maybe you can tap into the RS232 bus on the unit and monitor the commands sent by the software.
(2,818 Views)
This "older version" has source code:
http://fabathome.org/wiki/uploads/4/45/FabStudio.zip
There are serial functions.
(2,817 Views)
