No data retrieved from a OPC server when usind DatasocketRead VI
I'm unable to retrieve data from an Eurotherm OPC server (LinOPC) using the DatasocketRead VI in LabView 6.0
The execution of the VI seems to be OK (erreur code is 0 (=OK)) , but the result is not correct.
Instead of a real, I get  4 attributs (Quality, Timehigh, Timelow, et Timestamp) (see attached pictures)
I do not have particular problems when §I use another OPC clients like OPC Scope
(3,135 Views)
Hello.
Does the behavior you notice occur just for the first read value or does it always occur?
Have you got the same result if you run LabVIEW examples?
Mehdi A
NIF AE
(3,101 Views)
This behavior always occurs. The result are the same, excepted that the value TimeLow increases rapidly.
I have the same results when using the Datasocket VI examples.
(3,086 Views)
Hello.
I noticed in the print screen you sent in your previous post that you didn't choose any data type as an input of the DataSocket Read function.
I think you should specify the data type you are attempting from the OPS server.
Regards
(3,067 Views)
According to the datasocket_read VI, the input 'type' should be a variant.
I didn't fully understand what is a variant, so I connected a constant to this entry (as done in the DS_Reader exemple VI)
As a result, I have now a single value, which is:
0.000E+0 if I connect a REAL (EXT/DBL/SGL) constant
0 if I connect a INTEGER (I32/I16) constant
So the type is recognized for execution, but the value is still wrong
According to the OPC server, a value of about 22.5 is expected, in DOUBLE format.
I have another proof that the OPC server receives a query from labVIEW: The query counter increases each time I run the VI
(3,049 Views)
