No code error, loading file not appearing
Greetings,
can anyone please run the VIs attached, and then load the csv file. Why is there no graph appearing? I have previously tested the code inside the load Value Change, it worked... but not when I try to include in this vi.
Please debug what could be wrong. I tried connecting numeric indicator to see if the FOR loop is counting, it does.. as can be seen in the indicator.
any help would be greatly appreciated.
(3,257 Views)
Hey,
You haven't wired your delimiter to the Read Spreadsheet VI.
CLAMaxime -- Kudos are a great way to say thank you
(3,232 Views)
omg. that's such a silly mistake, thank you so much for pointing out! I really did not notice..  was trying to find out whats wrong the whole day.
(3,228 Views)
