10-04-2007 12:20 PM
10-04-2007 09:57 PM
10-05-2007 08:36 AM
They're right next to the TDMS in the File I/O palette. The icons just say "data storage" but they write to .tdm file types. If I hover the mouse over some of them the cursor turns into an hourglass and won't pick them up (the help window does not update either).
I just noticed that there are TDM to TDMS conversion VIs there. They seem to work. Also, 'Merge Queries' and 'Delete Data' as well as all of the VI in the advanced palette seem to work. It's just the first six main Data Storage VIs that cause trouble.
I checked this on two independent systems (Both: Dell PIV - LV 8.2.1 Professional). Same exact behavior. Can anyone verify???
10-08-2007 02:50 PM
10-09-2007 01:47 AM
10-09-2007 09:37 AM
Thanks Emilie. That's what I assumed so I have already updated to the TDMS VIs.
Yong, that is correct. My action engine VI for TDM data storage showed up broken with an "unable to compile" error. To make it more confusing, I opened the old action engine with the old TDM VIs in 8.2.1 this morning to verify the issue before I posted it and it opened fine. It seems to work (at least on its own). However, I still can't simply drop an old type data storage VI on the block panel when I'm using 8.2.1. The hour glass cursor appears and it won't let me drag the VI icon off the palette. Again, it's only the first 6 VIs. Merge Queries.vi and the rest seem to be OK. If it was just one PC doing this I would assume I have a bad install but it's on two systems.
Since I'm now using the TDMS VIs anyway this is not a problem, let me know if your system exhibit the same problem.
Thanks All,
K
