No Supported Devices in DAQ Assistant
I have an Agilent 34401A instrument and I'm trying to measure voltage using Labview. When I try to use the DAQ Assistant, it shows that there are no supported devices found. How can I fix this?
(2,956 Views)
I assume you have the appropriate drivers for the instrument
http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=978
hope it helps
Please remember to accept any solutions and give kudos, Thanks
LV 8.6.1, LV2010,LV2011SP1, FPGA, Win7
(2,955 Views)
I have downloaded the drivers but it still does not show. Please help
(2,951 Views)
It is not supposed to show up in DAQ Assistant. It is certainly not an NI DAQ device which is what the DAQ Assistant is for. You have the functions for the driver on the Instrument I/O palette. Simply look at the example for it (Help>Find Examples>Hardware Input and Output>Instroument Drivers>LabVIEW Plug and Play).
p.s. There was no need to download anything. The driver has been included with LabVIWE for many versions.
(2,945 Views)
