No Signals Generated
mhh ... looks like you get 0V with noise, but im still confused.
in your first code picture you use AI2, then your first DistributedSystems image, you have 0V(with noise), but it does not show which hardware port you are looking at,
in the next you have a value of over 2 for AI2, but it is unclear wether thats an absolute value, or something like 10^-6 comes after.
did you try turning it on and off again? .. i mean .. can you vary your turbine flow to check that this is represented in DistributedSystems viewer?
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 11 of 13
(812 Views)
no matter if the turbine is turned on or off I still get the same values every time. Yes, these are just the noises  10^-6
Message 12 of 13
(804 Views)
Accepted by topic author Hamada1982
then its time to assert your assumptions 😉
e.g. test the voltage change with some fancy meter on the wire going into your crio,
and consult the documentation for correct wiring.
this i cannot help with, i only know a little programming, no electricity stuff 😞
Message 13 of 13
(797 Views)
