Nilvaiu Error (Resource not found)
I have developed an application that uses DAQmx to take data.  While running in development mode, the software works fine.  When I generate an executable and run the code, I get the Nilvaui.dll resource not found error (see attached).  I can turn off my antivirus (AVAST) and it works fine.  Any suggestions other than using a different anti-virus or non at all?  By the way, I already repaired Max and rebooted my computer.  The application is running on the same computer that the development system is on.  I am using Labiew 2014 Pro.
(3,187 Views)
https://www.ni.com/en/support/security/configuring-software-and-hardware-firewalls-to-support-nation...
It looks Like AVAST is stopping traffic on a port needed by your app.  The link above will guide you to drill the right holes in the settings
"Should be" isn't "Is" -Jay
(3,171 Views)
