Ni vision
Good morning. We have problems with ni vision on MyRio, the video is very lagging. Nobody faced such a problem?
(2,223 Views)
Could you please be a little more descriptive with this issue? For example, you could share a snippet or attach your code to show how you are acquiring images so we can verify if you have any image processing or function that could delay your acquisition. Also, it could be helpful if you specify which camera you are using, the expected frame per seconds, the resolution, the pixel format, your current LabVIEW versions, and so on.
Warm Regards,
Alejandro Balma
(2,184 Views)
