Ni dacq problem
Hello guys , I'm a new dev on a french lab and i have a problem with my Ni dacq simulated device ,
i want to generate values to test my Labview program but some values stay on 0 ( always the 2 last values )
do you have a solution to fix it ?
(2,322 Views)
(2,306 Views)
Hi krhonos,
create your own simulated measurement values.
Split your test into two parts:
  1. test the DAQmx code using a simulated device.
  2. test the signal analysis using your simulated measurement values…
(2,280 Views)
If its a simulated device you won't be able to actually control those things. (I wish it were possible though)
Your best bet is using the simulated device to see if the software handles well the channels, configuration, the tasks, etc.
To actually test with values you're going to need to simulate your own data, which means creating VIs or something that can generate that fake test data.
(2,244 Views)
When the data comes out of the DAQmx Read, just multiply those last two channels by 0!
(2,235 Views)
