09-04-2007 07:31 PM
09-04-2007 08:33 PM
The x axis can be whatever you want it to be. If you wire an array of time values to it, it will be time. I don't quite understand how you are using the XY graph in the first place. Ther is no such thing as a XY waveform chart. It would seem to me, that you would want to use the waveform graph. You've got the abiltiy to use cursors and the x axis can represent in a much easier fashion. Why don't you post the code you have written?
p.s. You can measure delta t between the two traces without the x axis displaying time. It can all be done automatically without manually using cursors.
09-04-2007 08:50 PM
09-05-2007 12:09 AM
09-05-2007 06:23 AM
09-05-2007 06:29 AM
09-05-2007 10:51 AM
Phooi,
I don't understand some of your comments. You have no XY Graph in the example you posted. There is just a waveform graph. You also have the waveform graph x axis set to 0 digits of precision.
Without seeing the actual waveforms that you are capturing, I can't say exactly how to perform an automatic measurement but you could try using a Basic Trigger Detection on each of the channels. You can set the location mode to time and then just subtract the trigger location of one from the other.
09-05-2007 12:11 PM - edited 09-05-2007 12:11 PM
Message Edited by Yardov on 09-05-2007 12:12 PM
09-05-2007 07:22 PM
