Ni 9403 configured to use as input and output
I am using NI9403 TTL I/O module in my application. Do I need to configure each I/O line of the module to use as input or output? Thanks
(2,768 Views)
If you are using the cRIO then you should look at this kb
Amit
(2,752 Views)
