Newport XPS controller- RV240PErotation stages via labview
I have a problem with xps c8 controller woking via labview. The XPS controller works well via webface GUI. And I think I've already installl the labview driver of XPS C8 controller and copy them to labview user lib. The motion stages are also from newport, RV240PE. I want these two stages can move at the same time, their motion speed can also be changed and their positions can also be tracked.
My problem is that I cannot even make them move via labview. There are labview samples go along with Newport instrument. When I run the sample VI ( XY sample motion), a file log window popup. I have no idea which file need to be loaded. When I made some modification to the VI, the stages still cannot move, and an error code -19 came out.  What can I do to slove this problem? Any suggestion for labview programming. By the way, I've already get trained of labview core 1 and 2.
Appreciate your help in advance.
Menglian
Message 1 of 13
(3,945 Views)
Let's see some code so we can get a better idea of where you are at.  🙂
Bill
CLD
(Mid-Level minion.)
Message 2 of 13
(3,940 Views)
Message 3 of 13
(3,937 Views)
Have you put probes on the error wires to see where your error is originating?
Bill
CLD
(Mid-Level minion.)
Message 4 of 13
(3,932 Views)
It seems there are two errors. Here are the printscreen.
Thanks.
Message 5 of 13
(3,925 Views)
I'm thinking the first error is causing the second.  Try troubleshooting the communications error.
Bill
CLD
(Mid-Level minion.)
Message 6 of 13
(3,892 Views)
Hi Bill,
Thanks. Is there some thing wrong with the communication between XPS contorller and PC via labview? It's fine when I use the webface. If so, what can I do with it?
Menglian
Message 7 of 13
(3,886 Views)
@menglian wrote:
Hi Bill,
Menglian
You have a communications error that needs to be addressed before anything else will work.  I can't really tell what it is, though.  The error test isn't very helpful to me.  Maybe someone else knows?
Bill
CLD
(Mid-Level minion.)
Message 8 of 13
(3,879 Views)
Hi Bill,
Thanks so much for your help. When I run other sample VI provided by Newport, it worked well. The cofiguration VI, it can read all the defined group, which means the communication between XPS controller and PC is good. What do you think?
Menglian
Message 9 of 13
(3,860 Views)
@menglian wrote:
Hi Bill,
Menglian
Have you tried modifying the example to suit your needs (and saving it as a new VI, of course)?  Or maybe you can compare the initialization to yours?
Bill
CLD
(Mid-Level minion.)
Message 10 of 13
(3,848 Views)
