Newbie trying to figure degrees per second
OK I have Labview 7.1 and I am trying to calculate Degrees per second of a rotating shaft. I can not figure out how to take a reading and store that let the vi run then take another reading say in 500ms then calculate the DPS. I am new to labview and just having some brain lock. Any help will be appreciated.
(2,607 Views)
Hello antique,
just use a shift register... See the changed attachment!
(2,599 Views)
That seems to have worked. I did tweak a little but for the most part it worked great. I had to add a Sample compression to smooth out the readings. Please see attached and thanks for the help.
Antique
(2,583 Views)
