Newbie Labview Question: Array of clusters
1: i am a student
2: this is not homework or a graded project
3: I'm a pretty capable programmer, but that's in text-based languages. 😉
I have a sensor feed which contains 4 channels. I need to leave all 4 channels active, but I want to select one of them to graph at any given time. The data from the NI driver for the hardware comes as a 1x4 array of 2-element clusters.
Normally, I'd just index to the desired element in the 1x4 array, and feed that cluster to the appropriate graphing tool, but I'm missing something. I swiped a display element from the NI driver example VI's, but any time I insert blocks between the data feed and the graph I get "bad connection" errors.
I've been googling and book-looking for several days now, to no avail, I'd appreciate any help in this question.
in the image at ( http://dl.dropbox.com/u/4286123/LabviewHelp.jpg  ), what block do i need to insert into the highlighted wire to be able to select and graph only one of the 4 data channels, controlled by an integer source?
Many thanks.
(4,541 Views)
Can you post your image here?  I can't access the link you provided because my of my company's policy.  It's blocked.
You can post the image by clicking on the Insert/Edit Image button in the menu bar above.  The icon looks like a tree.
- tbob
Inventor of the WORM Global
(4,532 Views)
18237i9095BF330A2E009A
As requested...
(4,525 Views)
Accepted by topic author brianlojeck
Use the Index Array funtion found in the Array palette.  Wire in the index number of the waveform you wish to display.
18239iBE8F6E8F60C448B2
- tbob
(4,518 Views)
I swear I tried that before, and it didn't work...
ah well, it works perfectly now. Many thanks.
(4,502 Views)
