NewVal in Event Structure
How do I change the name and color of that little box that is inside an event structure.  It seem to default to blue and say Time or Source or something like that.  I need mine to be green and say NewVal.  Can anyone help!
(4,570 Views)
These "boxes" are event data and they depend on the event you choose. It will be green and say NewVal if you use a value change event for a boolean. If you don't see the newval terminal, you can click and drag to make it longer and show more terminals. You can also click each of the terminals to decide which element it will show.
To learn more about LabVIEW, I suggest you try searching this site and google for LabVIEW tutorials. Here and here are a couple you can start with. You can also contact your local NI office and join one of their courses.
In addition, I suggest you read the LabVIEW style guide and the LabVIEW user manual (Help>>Search the LabVIEW Bookshelf).
___________________
Try to take over the world!
(4,557 Views)
