Network Shared Variable Description
I've created alot of Network Shared Variables through Project Explorer...and i have also added a description for each one in the shared variable properties screen
Could someone please tell me how i can get access to the description through LabVIEW?
Many thanks
Mike
(3,726 Views)
Have a look at: http://digital.ni.com/public.nsf/allkb/2E8BAD0EA218A7558625712E0003F044?OpenDocument.
At the bottom of the document it shows that the SharedVariableIO Class has a property called "Description" .
André (CLA, CLED)
(3,712 Views)
Thanks for that - the only problem i have now is that if i put a shared variable on the page and link it to a display. I then have to create a seperate reference to the shared variable io server to get the description. Is there a way of using this same reference to get the value so if i change that both the description and value update. At the moment i would have to change this reference and then also the shared variable itself.
Hope i have made myself clear
Mike
(3,704 Views)
Hi Mike,
Would it be possible for you to post your code so I can better see what your doing?
(3,682 Views)
Hi attached is a sample of code in which i am viewing a value and also its description.
Ideally id just like to have the channel name once and the description and value be taken off that, rather than if i ever change it , then have to change the input to the description and also the variable displaying the value. Hope that makes sense
Regards
Mike
(3,661 Views)
Hi Mike,
I'm not sure if what your asking is possible without needing to rename the channel, as the channel is a reference wired to the input. I will ask some collegues today and get a response back to you.
(3,639 Views)
