Network Analyzer labview program
My grid is going to be a lot smaller than 100 x 100. When i said that it was just arbitrary. It's going to be more of a 10x10
Message 21 of 75
(2,763 Views)
See attached example for one way you can generate the file. For the headers just write out the headers before you go into the loop to write the data. I'm sure you can figure out how to write out the headers based on the way the 2D array's size is calculated. Smiley Wink
Message 22 of 75
(2,750 Views)
Alright let me see what i can get. Thanks
Message 23 of 75
(2,745 Views)
Note: Not to lead you astray, but you can combine the 3 Replace Array Subset into one. You'd just need to build a 2D array out of the 3 individual 1D arrays. The VI I showed you was for demonstration.
Message 24 of 75
(2,726 Views)
With the 3 individual arrays I have for Magnitude, Phase and Frequency. How can I combine that into a 2-D array. I have a build array function but that just converts it to a 3-D array
Message 25 of 75
(2,719 Views)
And one more thing that kind of confused me on your sample program that part that says "Simulate network analyzer data" does that represent the section of code that i have my arrays for Magnitude Phase and Frequency? Because I wasn't sure what the 0, 10 or 20 meant.
Message 26 of 75
(2,711 Views)
Don't know how you'd be getting a 3D array. If you wire 3 separate 1D arrays into a Build Array function the output is 2D. See attached mod.
Yes, it does. The 0, 10, and 20 is just dummy data. Since I don't have your network analyzer.
Message 27 of 75
(2,692 Views)
When i ran your previous program, is the shift register necessary/
Message 28 of 75
(2,689 Views)
The shift register is present in both "collect NA data" and "collect NA data MOD". It's necessary in both. The reason is that you pre-allocate the array and you need to update the array in each iteration. The shift register will contain the current state of the array. If you just used a tunnel then you'd always be performing the replacement on the original array, rather than the current array.
Message 29 of 75
(2,682 Views)
I get an error when i connect my transpose to my replace array subset.
19771iCCD6D13B18A07F98
Message 30 of 75
(2,680 Views)
