Network Adaptors
Hi There,
Is there any way to programmatically populate a list of a PC's Network Adaptors?
For example, the attached screenshot shows my PC's network adaptors.  Could I programmatically get LV to report the "Local Area Connection 3" and "Local Area Connection 4" strings.
Or, even better, the Device Name strings?
Many Thanks,
Dan
Dan
CLD
(3,864 Views)
Those aren't the network adapters. Those are network connections.
See here: http://www.eggheadcafe.com/software/aspnet/29220319/how-to-get-connection-name-or-how-to-setup-netwo...
(3,838 Views)
I use DevCon to find network adaptors on a system.
Then ipconfig to match network adaptors to IP address.
Omar
(3,832 Views)
Here is an example that uses .NET to retrieve this type of information.
Yes, I know that .NET is large and bloated and someone will complain, but it should work for you...
(3,803 Views)
