NetDDE connectivity problems using windows XP and 2000.
Trying to use NetDDE between two PC; one running windows xp the other 2000 and Labview 6.1 Prof. Dev. Each PC can ping the other. They are on different domains though.
Problem:
Used Knowledge Base 1959C0FR to setup DDEshare.exe and even used the examples provided, but it does not work. Any thoughts on things to try to resolve this problem.
(3,094 Views)
Wow, I am not real sure on this one. I was finally able to get it to run on my machine when I figured out that I could not use \\localhost\TestServer as a service but instead had to just use TestServer. I was not able to get any other PCs to connect to it though, however I think it may be a privileges thing.
I did find this app note that also discusses how to use DDE and LabVIEW.
Using DDE in LabVIEW (Windows Only)
I hope it helps.
(3,094 Views)
