.Net Interop Assembly naming control for fields / cluster
Using LabVIEW 2015, I've created a LabVIEW project with a single VI that takes in a cluster of my own definition, perform some simple data modification on the cluster, and then return it to the caller. I've created a build specification and compiled it as a .NET interop assembly under .NET 4.0 environment. When referenced in a C# application in Visual Studio, I find the naming of the class/enum/struct/field in the interop assembly, esp. the inner cluster and the enum nested in the cluster, make little sense to me for maintainance in the future. I would like to control the naming of these class/enum/struct/field in the interop assembly during its generation in LabVIEW. Is it possible to do this with LabVIEW?
p/s:
I've attached the LabVIEW project and Visual Studio solution for reference.
Message 1 of 1
(2,759 Views)
