.Net File Open Dialog [ ShowDialog() ] freezes Labview
I'm using the .Net File Open Dialog so I can have multiple filter patterns in my dialog. When I run the VI, it hangs at the ShowDialog() call. I can see this when I highlight execution. I've minimized everything, and the Open File Dialog is not being displayed anywhere.
If I try to Abort execution, nothing happens. If I close the VI, Labview hangs displaying the "Resetting VI: ..." dialog.
I'm running Vista Professional, Labview 2009, and using the System.Windows.Forms(2.0.0.0) .Net Constructor
Thanks for your help,
Kirk
(5,208 Views)
Accepted by topic author kmactavi
Not sure what you are doing since you did not post your VI. If I had to guess I'd say the issue is that the VI is not setup to run in the UI thread (VI Properties -> Execution), which is required for some .NET classes. Attached is an example I wrote a while ago.
(5,197 Views)
That was the problem. Thanks!
Kirk
(5,171 Views)
