.Net Controls On Front Panel (DataGrid) Not Displaying Data
Charles,
You have many way to do this, ADO, ODBC, OLEDB, and SQL Client.
First what are you connecting to....
If It's only MS SQL Server 2000 or Newer the SQL Client Best.
If it's Active X Only connection then ADO is the Best Choose but Slow.
The ODBC is an older verision of OLEDB Connection And this is the General Connection.
ADO is a cheap warpper of OLEDB, and OLEDB is faster that ADO.
OLEDB can connection to SQL Server, But not with the speed and ADV. functions of SQL Client.
The ADO is found in ADODB .Net Library
The rest is found in System.Data .Net Library
I use the OLEDB to talk to Access and SQL Server and didn't what to develop two difference connection.
This "Fill Data Grid" is a simple form of what happens in the SubVI.
There are alot opt. for the connection and Auto Complete Update, Insert, and Delete Commands, other Functions
That is not the purpose of this Tread.
Maybe someone should start a Tread on .Net System.Data and Databases in .Net
Message 11 of 20
(4,068 Views)
i have got the solution for it.
i have displayed all the data from SQL server databse on a form using .NET object.
See the attachment.
Dev
Message 12 of 20
(4,036 Views)
What Attachment?
Check it, I don't see an attachment.
Message 13 of 20
(4,024 Views)
Using BindingContext and DataGridView's DataBindings.Add Method , It works, but DataGridView can not input Chinese! It display Chinese well.
Message 14 of 20
(3,870 Views)
Please do not ask the same exact question on three different threads. Same question here.
Message 15 of 20
(3,852 Views)
can you please post the code?
Thanks.
Dev
CLD Certified Engineer
Message 16 of 20
(3,765 Views)
Which code are you referring to, and whom are you asking? There's been several bits of code posted in this thread.
Message 17 of 20
(3,748 Views)
I was asking about the code for data display on .NET datagrid.
But fortunately i got the solution on the discussion forum in other link.
Thanks.
Dev
Message 18 of 20
(3,730 Views)
Dev,
Could you post the link to the solution you found? It would be helpful for all who stumble by this discussion forum.
Mehak
Mehak D.
Message 19 of 20
(3,714 Views)
Hi Mehak,
Here is the code attachment of what I have developed for displaying SQL database values into .NET Datagrid.
Hope this is the one you are looking for..
Message Edited by ddddddddddddddddddddd on 09-12-2008 10:27 AM
Dev
Message 20 of 20
(3,707 Views)
