Need to up convert from Labview driver from 7.1 version to 2011 version
I would like to upconvert the BERTSCOPE labview driver from 7.1 to 2011.  It gives error during conversion. I was wondering if NI can help me in converting the file properly from 7.1 to 2011. The Zip file is too big. but you can down load from Tektronix website
BERTScope Driver for LabVIEW V1.0.2
(2,775 Views)
What does the error say?  Is there an error code number?
If you do need help converting it, then it is better to provide an actual link to the file on the website rather than just saying to go get it there.
(2,771 Views)
There is the conversion board but 2011 can open 7.1 files. You need to provide the error. Also, it would be polite to provide an actual link instead of just saying the Tek website.
(2,769 Views)
Hi  Dennis:
I tried to Download the ZIp files. The Zip file itself is 9 Mb. When I download it , NI website says the limit is 5Mb
The Error message I get is
The attachment file size is too large. The maximum file size is: 5,120,000 bytes
That is one of the reason  I gave the link..
(2,744 Views)
But you did not give the link nor the error you get during the conversion. The error when you try to attach a large file is meaningless. I'm not about to browse the entire tek site when you should be able to provide a direct link to this driver and I'm not about to download the driver until you provide the conversion error.
(2,741 Views)
