Need to create text file as my memory .
hi all ,
              i need to use text file as my Memory (like eprom in controller) . i have to send address and data to write and address to read that data. is it possible to create.
Message 1 of 16
(4,287 Views)
Yes. Create a file of sufficient size, then read and write selected locations by first setting the file position. Use all low level file IO.
Message 2 of 16
(4,275 Views)
hi
Message 3 of 16
(4,260 Views)
No, but this seems trivial to do from scratch. What have you tried?
Message 4 of 16
(4,242 Views)
Here's something to get you started.
GCentral
Message 5 of 16
(4,218 Views)
hi crossrulz,
                      I tried to create its not working for me. Is it possible to get VI file
Message 6 of 16
(4,205 Views)
If you are using LabVIEW 2014, you can just save the image I left you and then drag it onto your block diagram.  It is what is called a "snippet".
Alternatively, you can post what you have tried and we can tell you where you went wrong.
GCentral
Message 7 of 16
(4,194 Views)
        I have attched my vi code
Message 8 of 16
(4,184 Views)
1) You need to set the file position
2) You should set the data type on the read to be a U8 to get that byte.
3) You told the read to read nothing.
4) You will need to put something in your file in order to read it.
GCentral
Message 9 of 16
(4,171 Views)
Try this:
Currently it read everything. It would be easy to change it so it reads only one byte.
Message 10 of 16
(4,154 Views)
