Need to add a "dispense fanta" enum
I am building a coke machine. Right now, the coke machine only dispenses Coke, but I need for it to dispense Fanta also. I am trying to add an enum constant for dispensing, but I couldn't get for it to work. Can someone take a look? I attached my code for reference.
(2,828 Views)
Edit the existing enum and add a new item. No separate enum needed.
(2,804 Views)
Not sure how to do that, can you explain? Thanks!
(2,802 Views)
Does that mean you did not write the program that you have attached? (If you created the original enum, you would know how to add entries!) Have you done any LabVIEW tutorials? What have you tried?
(2,798 Views)
Accepted by topic author Seacreature2002
Right click on Enum then click on open type def it will open front panel of that enum it that right click and go to edit item.
Expand.Evolve.Influence
(2,797 Views)
