Need to Convert from Waveform or Array of Waveforms to an Array in Labview 6i
I am currently using the AI hardware trigger VI to do a data collection scheme. The sub VI outputs an array of waveforms, the trigger waveform and the signal waveform. I need to get the signal waveform into a regular array (2D?) so that later portions of the program can read the array in. I know this is very easy in version 8.0 but 6i is what I have to work with.
What I am trying to do is have the subvi generate a single column of data points of a known length and after each trigger have the program add another column to the array. At the end a seperate program will go through and average each row.
Attached is the program which has been written so far.
(2,742 Views)
It's no different in 6.0 than in 8.0. From an array of waveforms, if you only want the y data from a single waveform, use the index array and then Get Waveform Components (Waveform palette) as shown below. You also have the option of returning just a scaled array from the AI functions. Right click on the AI function you are using and you should be able to select Type>Scaled Array.
Message Edited by Dennis Knutson on 07-10-2006 09:16 AM
(2,729 Views)
Thank you,
I believe that has fixed my issue. The concept I missed was the ablity to change which component was being extracted for the Get waveform component function.
Christian
(2,718 Views)
