Need help with the Matlab Scripting VI
I have Labview7.0 and Matlab 6.5 Installed on the computer.I was trying to use the Matlab Script VI in Labview and it worked. But when I tried to use it again after 3 days, it returned an error saying that it is for instructional purpose and not for Research or Commercial Use and the Labview is getting stuck. Can anybody please help me with that.
(2,515 Views)
Hello Medha,
Thank you for contacting National Instruments.
From the information you have provided, I am not sure what is causing your problem. Make sure that you do not have an evaluation license for LabVIEW.
What, if anything, was changed in your VI before it stopped working? Will it run without the Matlab script?
If you continue having trouble getting your VI to work, please respond with more information. If you like, you can post your VI (along with any necessary sub-VIs) and I will take a look at it.
Have a great day,
Sean C.
(2,515 Views)
