Need help with serial communication
Hi everyone,
I'm trying to talk to a device using VISA serial but I have difficulty getting it to work. I've done this before with a different device and I'm following the same steps for this new device with no luck so far.
Here are the steps I tried:
1) Before I configured the port, the device manager was able to see the port. Also, I was able to control the device using the provided software for the device.1.jpg
2) I used NI-VISA Driver Wizard to configure the port. The software automatically filled in the options and I made no change to them.
3) After installing the .inf file, the port appeared in the device manager as this:3.PNG
5) The communication settings in MAX I/O5.PNG
There was no error when I sent in a command, but when I tried to read the buffer, I kept getting timeout error. The device uses checksum as the terminating character which I'm still trying to understand. However, according to the manual, I should be getting a message back regardless of what I send in. I think MAX isn't not communicating with the device at all.
Please help!
Thank you
(3,060 Views)
Have you tried using Wireshark to capture the USB comms ? It may give you some clues.
(2,983 Views)
Sorry for the stupid question, but how are you sending messages and trying to get responses from the device?
Given that you don't have a termination character, and the message seems to require parsing to know the length (it looks from the manual that the response is always 8 bytes, but the message reply can vary between 6 and 255 depending on the value of the length data byte), I'm wondering how you're managing in MAX. Or are you using LabVIEW?
GCentral
(2,970 Views)
When I hear "serial communication" I assume it's through a serial port (real or virtual) that appears as a COM port in Windows. I know technically USB is serial, but that's not usually what "serial communication" refers to. Is it possible that this USB device also appears as a COM port, maybe the "COM1" you have listed in MAX, or if that's not it, maybe there's an option in the driver properties to enable a virtual COM port? That would probably be simpler than doing USB communications like this.
(2,963 Views)
can you share your vi?
CLD Using LabVIEW since 2013
(2,919 Views)
