Need help with XY-graph
Heey everyone, i have a small problem:
I want to create 1 XY-graph which has several Y-axis (max 8), and they all have the same X-axis. The thing i tried is in the appendix of this post.
I think I have to bundle each y-axis with the x-axis but i`m not sure about that.
Thank you everyone.
Currently using labview 8.2.1
(2,733 Views)
Accepted by topic author Grasman
Use the context help to see quickly in which format you have to wire your data.
In your case bundle each data set with the time data and then array your bundles.
(2,727 Views)
Heey Jörn, it worked :D! thanks for your help!!
(2,723 Views)
