Need help with Windows media player "Network" property node.
I can play movies and display all sorts of attributes using property nodes. i.e. duration, status, current position, etc.
What I can't get working is the Network properties. bitRate, buffering statistics, download satistics, all read 0 when the movie is playing.
This happens whether I use a file on local drive or from the internet. (using mpeg files btw)
Any comments welcome. Thx
(2,787 Views)
You should definitely be able to do that. Look at the attached images for direction on how to do that. You need to right click on the property node and then select "select property". In the Select Property Window, double click on "network" to get its properties.
Chetan K
Application Engineering
Message Edited by CKap on 07-14-2006 01:29 PM
Message Edited by CKap on 07-14-2006 01:34 PM
(2,774 Views)
Hi Chetan
I could not find the jpg images. I know it;s an old thread. Could you attach the images again or at least give some directions?
Thanks in advance
Zahid
Zahid Hossain
Biomedical Engineer
(2,398 Views)
