Need help using labview to send a signal based on a voltage
Hello, I am a project lead the way student and for our senior project we are trying to use labview to read the voltage of a ph probe and when it exceeds a certain ammount we want to send a digital signal out of one of the DAQ ports. We have it set up that it can read the voltage and will send the signal but we do not know how to make one trigger the other. We are using a NI USB-6009 and would appriciate the help, we only have a few days left.
(2,354 Views)
What do you currently have set up? Are you continuously reading the voltage as a single read within a loop, or are you reading a waveform? Why don't you go ahead and upload the code.
(2,320 Views)
