Need help to split a string
Hi ,
    Im needing help to split a string like this .. A,B,C,ADV,ASDAS,ASDASDASD,AsDASD, ...instead of leters ll be numbers , but i get it using a string ... Need split it to put in a vector ,, each number in each position ....
Someone can help me ?  ..
Im using labview 6  ..
Here is the print screen of my logic ....
(27,606 Views)
Accepted by topic author faelnpaiva
Hi faelnpaiva,
all you need is "Spreadsheet string to array" with a "," as delimiter...
(27,584 Views)
Not sure what you are trying to do. Are you trying to take a string of comma seperated values and place them into an array? Have you tried the "string to spreadsheet array" function in the strings palette? It allows you to input a delimited string, select the delimiter (comma, tab, etc.) to parse the string, connect a template array (1 D or 2D of teh type of expected output, numeric or text if you just want).
Slow typer!
Message Edited by LV_Pro on 02-12-2010 12:07 PM
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(27,577 Views)
