Need help to simulate FSK modulation with the toolkit
I need help, I just need to simulate FSK modulation
1st step: I take text and convert it in binary table
2nd step: le binary table must be modulate and demodulate
3 step: le binary table is convert to text and the text must be the same as at start (I hope)
4 step: when modulation will be OK, I will have to put noise in the transmision, but this is an other history....
I use LabVIEW 7.1 with modulation Toolkit
Sorry for bad english.
Thank's for any help.
     French help welcome.
Ben
(3,627 Views)
Nobody? 😞
(3,618 Views)
How edit a message?
(3,609 Views)
Hi Ben.
In first I advice you should have a look at this VI "MT FSK Mod-Demod.vi"
Look at the zip file to follow the steps to open this VI.
You can edit a message during 5 minutes after posting it.
Best regards.
Romain D.
National Instruments France
(3,594 Views)
Thanks for your help.
I didn't know that there are examples. I will try them!!!
Ben
(3,588 Views)
The example is not too bad, BUT: when I want modulate and demodulate, I put, for exemple, 1000 bits et at the out, I juste have 995 bit. The modulation/demodulation lost somes bits Smiley Surprised
(3,577 Views)
Robot Sad
Message Edité par ben500fr le 03-03-2008 06:47 AM
(3,550 Views)
