Need help to modify multi-device Labview code
I need help to modify a previous single-device input and output code to a multi-device code in Labview 8.5.1. I need to collect analog inputs from 3 PCI 6251 cards (I have RSTI cable between them). The output signal will be from one of the 3 cards. The previous code (in attached .llb file, called "des_v2_Multi_Function_Synch AI-AO.vi") can work individually for each card to collect input and send out output.
In the modified code (in attached .llb file, called "des1_v2_Multi_Function_Dev_Synch AI-AO.vi"), there are some broken wires I don't know how to fix. To modify the code, I used the Figure 5 as a reference in the following website:
https://www.ni.com/en/support/documentation/supplemental/21/m-series-synchronization-with-labview-an...
Could someone help me to debug my modified code please? Thanks a lot.
Sincerely,
Jie
(2,950 Views)
duplicate post at https://forums.ni.com/t5/Multifunction-DAQ/how-to-do-DAQmx-synchronization-with-multiple-devices/m-p...
Please don't post multiple times with the same question!
(2,935 Views)
