Need help to convert 8.5 vi to 7.1
I need to convert my code (v 8.5) to older version (v7.1). Can any one help me?
(3,412 Views)
You did not attach the global VIs though the use of globals does not make much sense.
p.s. Spend 5 minutes and clean up your wiring. It's a big mess. It also doesn't make much sense to auto-index input arrays and also wire a value to the for loop's count (N) terminal.
(3,406 Views)
I know that the globals are missing but I have only this part of the whole code. I am also ignoring the globals too. Most important thing for me to generate CIN code in C, I do not care abot the wiring right now. So, I need the 7.1 version of this code.
Thanks.
(3,396 Views)
The first step is to save to 8.0 and I can't get it to do that with the missing globals. Post them or replace them.
You do realize that a CIN is considered obsolete, don't you?
(3,389 Views)
I know it is obsolete but I need this. I am attaching the 8.0 version that I converted by using evaluation version of 8.6.
(3,384 Views)
This should open in 7.1.  Also, Dennis is right.  CINs are considered obsolete.  I would consider compiling your code into a dll and using the Call Library Function Node
Jon S.
LabVIEW NXG Product Owner
(3,342 Views)
Thank you.
(3,333 Views)
