Need help in xy-graph
I like to plot a graph for the following scenario:
when there is 00000, it will replace with the previous value and plot with different color (red dot) & auto scale the y scale when x-scroll the window frame.
Attach with my vi.
Thanks and regards,
Simon
Message 1 of 10
(3,825 Views)
Can you give the file with version 8.5?
BEN
Message 2 of 10
(3,818 Views)
Message 3 of 10
(3,792 Views)
Thanks kate.
I'm out of office..
Message 4 of 10
(3,779 Views)
Accepted by topic author simon76
Hi !!
I've attached the solution for your problem.
It did'nt work because when you are scanning form string the dot you use in your seconds makes an error (i'm sure you had noticed that 🙂 ).
Furthermore, you cannot create 2 plots in the way you tried, you need a cluster of arrays (X &Y) NOT 2 arrays of clusters, that is the reason beacuse you couldn't connect the wire to the XY graph.
If you need anything else don't hesistate to comment here :).
Greetings from Spain
🙂 Don't forget Kudos 🙂
24272iAB6B982E1B4FF8B9
Message 5 of 10
(3,753 Views)
Hi Jordi,
Thanks for your help here.
It's no needed for dot replacement else it will really no working...Smiley Wink
Kudos for your explaination here....
thanks.
Message 6 of 10
(3,718 Views)
This all seems a bit too complicated. Here's a simpler way to do all this:
Let me know if you have questions.
Message 7 of 10
(3,716 Views)
Nice Solution ..Altenbach
Message 8 of 10
(3,708 Views)
Great one ...
btw, the time x-scale only display the first & last of the time stamp, is it possible  to have time stamp in between??
Message 9 of 10
(3,697 Views)
@simon76 wrote:
Great one ...
Right-click the x-axis and change to a different axis style
Message 10 of 10
(3,682 Views)
