Need help in writing data to a text file
I Need help in writing data to a text file. I want to combine the output of the 1st graph( X & Y coordinates) to a text file. I tried few things, the VI runs but the text file is not readable.
can you please suggest something.
Thanks.
(2,980 Views)
Before you write to a text file, you must convert arrray data to spreadsheet string format.
You could use 'array to spreadsheet string' function in Strings functions palette, and then write the resultant string to file using 'write to file' function
Or you can use 'write to spreadsheet file .vi' function in File functions palette
Sorry could not open and see your vi, hence this generic solution
Regards
Dev
Message Edited by devchander on 10-26-2006 05:16 AM
(2,977 Views)
Your basic problem is that you're simply concatenating all the numbers together, but you have nothing to separate them. What you need to do is:
  1. Eliminate the for-loop where you're converting the numbers to string. (Side note: you don't need a loop to convert an array of numbers to an array of strings. The string conversion functions are polymorphic.)
  2. Wire the X and Y arrays into a build array. This gets you a 2D array of numbers.
  3. Wire the 2D array into the "Write to Spreadsheet File" function.
That's it.
(2,952 Views)
