Need help in converting Traditional DAQ subvis to DAQmx configuration
i need to convert these vis (of traditional NI DAQ) to be used with a new DAQ card that supports only NI DAQmx.
please help me in this..
Can i use the same traditional NI DAQ VIs with NI PCI 6221??  if so how can I? does this device can be configured for traditional NI DAQ???
Kudos always welcome for helpful posts 🙂
(3,060 Views)
Accepted by topic author RENN
NI has several resources to help move from tradtional DAQ to DAQmx. A good place to begin is the Getting Started page. There is a tutorial on how to transition. There is also the compatability VIs that replace certain traditional DAQ functions with wrappers around DAQmx functions. The DAQ example you posted is pretty trivial and really should not take much time to convert once you get a basic understanding of DAQmx.
(3,033 Views)
thanks Dennis      :smileyvery-happy:
(3,025 Views)
