Need help here!!!!!!
Anyone done power quality analysis before? Pls share your idea with me and some .vi. I am a newbie.
What's the difference between THD found in (analyze->waveform measurment) andin(signal processing->frequency domain)
I tried 2 of them but the calculated result for THD are not the same.Which one is the correct answer? Or both also wrong?
My fo=50hz,
formula=a*sin(w*t),
#s= 21
higest harmonic=3
Why the harmonic frequency are not the same?
How to sketch out the harmonic analysis of a distorted current waveform?
Pls help.....
Thx
(2,736 Views)
K Tan,
After taking a look at your code, it appears that you are using the Harmonic Distortion Analyzer VI correctly, but not the Harmonic Analyzer VI. If you take a look at the detailed help for the Harmonic Analyzer, you must specify the window used for the Scaled Time Domain Waveform VI.
If you take a look at the help for the Harmonic Analyzer VI, you will see the details of how to correctly use this VI to make a THD measurement. I hope this is useful for you. Please post back if you are still having trouble. Thanks,
Mike
(2,670 Views)
