Need help developing something...
Hi Pete,
@Havordpete wrote:
Thank you so much for the solution Gerard!!
Who is Gerard?
@Havordpete wrote:
is it possible to attach the code script for your setup? Or make some kind of VI and attach it in your message?
I didn't save the VI after posting.
All the functions are clearly recognizable and you can recreate this litte VI within minutes! (It's a good exercise in practical LabVIEW programming…)
Message 11 of 13
(868 Views)
Apologies I read your username as gerard! I can read most of what you posted but I need help on one of the blocks if that is possible. I put an image of the block below so let me know what its called. Thanks for all the help so far!
Message 12 of 13
(850 Views)
Look at the icon.  The 2D grid signifies an Array so look in the Array palette...
You will learn most of the common VIs just by playing around with LabVIEW and letting yourself look through all the palettes in the Programming section.  Just give it some time...  😉
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 13 of 13
(841 Views)
