Need help debugging an issue
Attached is a presentation which displays the front panel, block diagram and error I am receiving. When I click the button to "run the progam" the program runs. However when I click the upper left hand button "tap" it creates the error shown. The purpose of the "tap" button is for the relay to engage for a set period of time, when you click on the button. How can this be fixed?
(2,748 Views)
Your attachments did not get attached.  Please try again.  Previewing a post may disconnect the attachments (although I thought they fixed that).
Lynn
(2,738 Views)
It would actually be best to attach the actual code, if you are allowed to.
(2,732 Views)
