Need help converting Python CRC-24q code into LabVIEW code
Hi, Need help converting this Python code that implements a CRC-24Q that I believe is correct into LabVIEW code.  I'm close since the CRC-24q table values match my reference Python code, but I'm having trouble where the CRC is actually generated.
Three examples listed in the Python code are:
CRC24 Result for empty input: FFFFFF
CRC24 Result for 'Hello, World!': 7480DA
CRC24 Result for '123456789': C3A394
The Labview code originated from this post:  https://forums.ni.com/t5/Example-Code/Calculating-the-CRC32-of-a-File-with-LabVIEW/ta-p/3496230
By DGardner.
SS
(1,752 Views)
If the python code is correct, the error in your LabVIEW code is that you're shifting the character in the input string instead of the CRCBuffer.  Then XOR the unshifted character with the shifted CRCBuffer
Tim Elsey
Certified LabVIEW Architect
(1,745 Views)
Accepted by topic author ShotSimon
As elset stated, you issue is you are shifting the wrong data for the 16 bit right shift. I did some other minor cleanup in the attached code.
(1,718 Views)
