Need assistance with noise filtering on my digital pressure sensor project
Hi llimpaull,
@llimpaull wrote:
I’m having difficulty recreating the program from the PNG image you sent.
Which "difficulties" do you encounter?
I just added a FOR loop and a BuildWaveform function… (And replaced the "bytes to read" with a large constant value.)
@llimpaull wrote:
Could you please share the VI file with me?
No, I didn't save the VI…
Btw. you should replace the i/o tunnels (VISA reference, error wire) of the FOR loop by shift registers. I forgot that step…
Message 21 of 29
(140 Views)
how can i use this thing
Message 22 of 29
(136 Views)
This is what I’m getting right now. What’s the problem here?
Message 23 of 29
(127 Views)
Hi llimpaull,
I don't see a problem apart from that "0" wired to dt of the waveform…
The FOR loop will take some time to collect 200 samples (at 10Hz it will need ~20s)!
Message 24 of 29
(121 Views)
Hi llimpaull,
By debugging you can learn how to use it!
What about a waveform graph to show the waveform feed into the analysis function?
Message 25 of 29
(120 Views)
deer gredw
i always got this eror and i dont know why?
llimpaull_0-1765540843145.pngllimpaull_1-1765540851551.pngllimpaull_2-1765541025373.png
Message 26 of 29
(106 Views)
I’m getting a plot in one graph, but nothing is showing in the other one.
Message 27 of 29
(91 Views)
Based on what is explained in this link, it seems that we cannot place this VI inside a loop.
So my question is: how can I acquire the full dataset in LabVIEW only once, and then send the complete waveform to this analysis VI so that it can calculate the blood pressure in a single step?
https://forums.ni.com/t5/Biomedical-User-Group/Can-I-use-the-Noninvasive-Blood-Pressure-Analysis-VI-...
Message 28 of 29
(82 Views)
Hey
I have problem with this
That’s exactly what I did, but the analyzer did not recognize my data. I also tried using the simulation, and it worked, but I don’t understand why the analyzer cannot process my data. Could it be a timing issue?
Message 29 of 29
(73 Views)
