Need an java script example on communicating with Labview
I prefer ActiveX and DDE, TCP/IP is ok but not very good in my case.
Pls. give me a part of Java file showing how to communicate with Labview using those methods. It will be great if you can attach the Labview files as well.
Thanks a lot for your help.
ljhfdy
(3,204 Views)
To see discussions on Java and the resources NI has to offer, I highly recommend using the advanced search page. Goto www.ni.com >> support >> advanced search (it is at the bottom--click on the words). This lauches the a new web page which allows the user to search the resources of interest. In your case, enter java labview in the all the words field and search everything. There are several good hits.
Jeremy Braden
(3,204 Views)
