Need Timestamp from the Array Index
@srsannasi  ha scritto:
Yes, I got the array index for the corresponding peak. The thing is to know the timing of that peak. Pl refer to the attachment. Thank you.
The timing of the peak is the element in the time array with the same index.
Paolo
Message 11 of 17
(568 Views)
Yes, thank you. But the problem is in extracting the respective time of the peak.
Message 12 of 17
(566 Views)
I don't understand. Try to explain better using more words and possibly an example.
Paolo
Message 13 of 17
(563 Views)
Yes, in simpler words, as in the attached screenshot, the maximum peak attained for Channel 1 is 4.50127 with its array index is 105. The requirement is, how to display its respective time? Thank you.
Message 14 of 17
(548 Views)
Check the attached vi.
Paolo
Message 15 of 17
(539 Views)
@pincpanter
It works well  and I learnt the logic now. Tons of Thanks to you for this support.
God is Love and God is always Great.
Message 16 of 17
(533 Views)
And to get the times for all peaks, you would use a FOR loop, of course.
Message 17 of 17
(508 Views)
